Further updates. Had the Willwood Calipers apart twice. Measured the rotors, bores the pistons. Polished everything with 1000 grit. They still don't retract as I would like but are better. XS 16v Battery is installed. The regulator swap in the alternator works great. Front shocks are repaired and installed. Decided to upgrade the 20 year old rear Koni shocks to Afco big guns. They should be here by Tuesday. Data logger records A/F, RPM, and G's. Down loads correctly. How ever we're having an issue with the driveshaft speed sensor reading. Found a slight intake leak on #2/4. So that's fixed as well. Fixed a minor trans leak at the park cable housing. Hope to test this week.
Doug
