so its been so long since i have worked with Alumi parts i stripped my drain plug on the trans pan after 3 times of changing the Hyd 303 fluid to flush out the trans system. and let me tell u the dip stick tube that the fluid goe's in is about the size of a pencil so it takes 3 hours to get 4 quarts in.
