I have a a heck of a time with the axle play on my 69 RR. I only replace the seals. I backed off the adjusting wheel and for some reason it will not adjust the play on the left side but does the right side. I put left side in first hit with a rubber hammer to set bearing and then tighting 5 bolts. Any Ideas Help Thanks Tom RR
