I never tried it with a stock style pump but with the Carter street/strip and 5/16 fuel line we've done 11.1 @ 121 mph. 1.54 60 ft. best.
my junk has been 119.92 with a mechanical pump, for years i ran 5/16 line and the carter pump. i switched from that to the cv products r5p7 nascar pump (bolts right on a big block with just a touch of clearancing needed) and 3/8 line and didnt gain anything. im just curious if my daughters car will gain any mph with the fuel pump swap. i guess ill see saturday. do you spray your car with a mechanical pump?
