Frank, if you open the pictures using microsoft paint, you can use the "reduce" option in the menu bar to reduce the size (how many megabits) of the file. Resave the file under another name (so you don't overwrite your original) and then you can edit that file all you want to get it to the size you need. If you knew this already, forgive my intrusion.
