I'm under the impression that the OEM Mopar air conditioning compressors are a lot better than the current after market Sanden units
I would make sure first before switching
I have a 1940 Ford Tudor sedan that I'm going to add air to and I want it as cool as possible, it is dark blue and relative big inside so the air will need to cool a lot of area. I've bought a trunk mounted unit from either Vintage Air or Southern Air but none of the under hood parts or lines yet. I'm thinking of adding a small under dash combination heater and air conditioning unit for heat and defroster also., lots of bridges to cross soon to get that car done
