Originally Posted by Cab_Burge
It sounds to me like it is(the connection or circuit) either worn or corroded causing the intermittent issues your having twocents
Do you live in a high humidity area, winter and summer? If so look for corrosion, if not look for wear twocents
Yes, I live in central Florida and the humidity is high most of the time. Thanks for your input. I’ll do some checking.
