Does anyone else have results in this cam? Just installed one In my ramcharger and I am extremely impressed with the results.
Just swapped from a 230@050 .525 on 112lsa hyd. roller to the trick flow cam.
This motor made 490hp and 553tq originally. 9.98 to 1, ported sidewinders,rpm intake,
850 Holley, 1 3/4 headers.
I only have seat of the pants to report but this thing now pulls much much harder surprisingly even down low from 2500 way snappier and has much more torque all the way through and pulls to 6k and seems to like 6500 shifts.
I did not expect to gain more low mid range from this swap but it did and it feels significant. I purchased a 3600 converter to replace my
2k stall. I haven’t done the swap yet and I’m not sure it will even be necessary. I’ll likely do it anyways. But this much bigger cam did not hamper the torque down low it increased it.
I can just roll into the throttle now at 25mph and it just starts hazing the 36” tires without any effort all the way through second. It didn’t do that before. I give this cam a 2 thumbs up. 👍
I feel this motor has to be making 580ft lbs and an easy 550hp.
Cam is 243/247@050
.600/.600
108lsa with 104 centerline.
I have this combo in my 500" stroked 440. I'm using the TF 240's OOTB checked, but no changes... 10.75:1 and I love how this thing makes power. I even have my 6 pack setup on it and its not a bad street combo. I'm sure I'm leaving a bit on the table with the 6 pack intake but I'm happy!!!!! I used the Howards max effort lifters.... these hydraulic rollers are noisey but I can live with it....
