Ask yourself - if it was drain down where would the fluid go?
A - Start with a warmed up trans, set the level to full in neutral.
B - Shut the engine off long enough to get your symptoms.
C - Before starting see if the fluid is much higher on the stick then in A above.
If not you have another problem.
