Originally Posted by chagjr
Originally Posted by GODSCOUNTRY340
Okay, that's a neutral balance convertor, no weights on front but the bite flex plate is for using that convertor on a cast crank engine. If your engine is a forged crank engine that is the wrong flex plate for it. Use your new flex plate.
Thanks for all of the help. I have another question regarding the transmission I removed.
What did this come out of? This section was hitting the frame in the tunnel that the tranny cross member attaches to.
It kept the transmission down a little causing the steering linkage to hit the oil pan when making a right turn.
The new transmission tail shaft housing is what I am used to seeing. It does not have that.
You said this is in a Dart (A-Body), what oil pan are you using?
A standard big block oil pan doesn't clear the center link/idler arm on a Dart, it has to have a recess in it or be reworked for clearance.
Kayse can't keep up at all now. lol
