I'd use a 5.9 Magnum instead of the diminutive 5.2. I was under the impression that all 318's and 5.2's are internal balanced while 5.9's and 360's are external balance. If I swap to a 5.2 I can use the flywheel from my 318. You are correct. I would caution you that you can't put to much of a cam in the 5.2 magnum with the stock pistons without running into valve to piston problems. I don't know what the specs on that cam are but anything over .470 lift with 212@.050 is probably going to be a problem and that is with the stock .050 or so head gasket. Remember that most of those aftermarket cams are listing the lift figures with a 1.5 rocker and magnums use a 1.6 rocker. Edit: I just looked up that cam and while it does say it's for the 1.6 rocker ratio i don't think it will fit with .506 lift and 216/224 duration @ .050.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
