Re: Won't start, I am throwing in the towel
[Re: Jim_Lusk]
#2774714
05/15/20 01:38 AM
05/15/20 01:38 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
has spark, has fuel.
new timing chain. when I installed it, I made sure dots on gears are lined up: top gear at 6 o'clock, bottom gear at 12 o'clock. also, right now, rotor points at #1 cylinder when 1st cylinder is TDC on compression stroke. With the dots pointing at each other (crank at 12 and cam at 6) you are on #6 firing NOT #1... When the dots align like you had them the motor is starting on the first stroke which is the overlap stroke when the exhaust valve is closing and the intake valve is opening, the distributor rotor will be, and should be, pointing at #6 spark plug wire
Entire Thread
stephen
09/01/19 12:11 AM
slantzilla
09/01/19 12:14 AM
Sniper
09/01/19 12:17 AM
Alaskan_TA
09/01/19 12:25 AM
stephen
09/01/19 12:28 AM
mopars4ever
09/01/19 12:32 AM
Sniper
09/01/19 12:33 AM
stephen
09/01/19 12:39 AM
Kern Dog
09/01/19 12:52 AM
Alaskan_TA
09/01/19 01:14 AM
stephen
09/01/19 01:16 AM
Powerflow
09/01/19 02:08 AM
RapidRobert
09/01/19 02:51 AM
PhillyRag
09/01/19 04:54 AM
RTSrunner
09/02/19 02:42 AM
RapidRobert
09/02/19 04:17 PM
stephen
09/04/19 06:36 PM
HemiSportFury
09/04/19 07:06 PM
stephen
09/04/19 07:16 PM
Andrewh
09/04/19 07:37 PM
HemiSportFury
09/04/19 11:14 PM
Sniper
09/05/19 03:10 PM
HemiSportFury
09/05/19 07:45 PM
stephen
05/13/20 09:25 PM
mopar97
05/13/20 09:45 PM
stephen
05/13/20 10:50 PM
Cab_Burge
05/14/20 01:49 AM
Sniper
05/14/20 02:37 AM
Finoke
05/14/20 06:28 AM
stephen
05/15/20 01:36 AM
Jim_Lusk
05/15/20 02:48 AM
Cab_Burge
05/15/20 05:38 AM
stumpy
05/15/20 03:55 PM
mopar97
05/15/20 08:38 PM
AARCONV
05/15/20 10:22 PM
CMcAllister
05/15/20 11:35 PM
stephen
05/16/20 12:55 AM
mopar97
05/16/20 04:34 AM
stephen
05/16/20 06:20 PM
CMcAllister
05/16/20 06:49 PM
roadrunninMark
05/16/20 07:42 PM
jwilson 61
05/16/20 10:25 PM
stephen
05/17/20 01:43 AM
Jim_Lusk
05/17/20 02:47 AM
Cab_Burge
05/17/20 05:14 AM
stephen
05/17/20 06:33 PM
stumpy
05/17/20 06:42 PM
Cab_Burge
05/17/20 07:09 PM
mopar97
05/18/20 01:14 PM
stephen
05/18/20 11:03 PM
buildanother
05/19/20 12:37 AM
CMcAllister
05/19/20 12:51 AM
57Fury440
05/19/20 01:11 AM
mopar97
05/19/20 12:53 PM
stephen
05/19/20 03:08 PM
lockjaw-express
05/20/20 11:14 PM
RapidRobert
05/21/20 02:16 PM
moparx
05/21/20 02:58 PM
LimelightCuda
05/26/20 01:44 AM
57Fury440
05/28/20 08:42 PM
NITROUSN
05/21/20 03:26 PM
BadMoonRacer
05/22/20 01:36 PM
moparx
05/22/20 04:22 PM
roadrunninMark
05/25/20 03:23 AM
stephen
06/15/20 12:38 AM
RapidRobert
06/15/20 12:47 AM
Sniper
09/05/19 03:11 PM
62maxwgn
09/05/19 05:16 PM
kenworth_goose
09/01/19 01:58 PM
Sniper
09/01/19 02:11 PM
dart4forte
09/01/19 03:18 PM
1968RR
09/01/19 03:11 AM
Jim_Lusk
09/01/19 04:14 AM
IMGTX
09/01/19 07:21 PM
500ciDuster
09/01/19 11:04 PM
AARCONV
09/02/19 02:30 AM
gtx6970
05/13/20 11:00 PM
