Try a backcut if you use the Mopar OEM type valves, That picked up flow a bit on my 273 heads I was messing with a couple of years ago. We got it flowing about 180 cfm @ .420" lift without messing the bowl cuts. I ran out of money on that project before we tried any valve job angles, etc. Not bad for a stock head with 1.78" intake valves.
Floyd Lippencott IV
