Ok did some checking and with engine off pressed down on brake pedal and held then started car and pedal might have moved 1/4 inch. Hooked up an external vacuum pump that pulls 27 inches and had the same result but with the engine off I could hear a shhh sound very time I pressed the brake. Also measured and the pedal is only moving 1.5 inches from rest.
