I have the correct E body shifter rods, and the correct bracekts on the transmission.
The diameter discretion is on the actual hurst shifter mechanism and the non adjustable end of the E body shifter rods. I will measure tonight to verify the diameters. I could turn bushings out of delrin or bronze if needed. I just assumed there were bushings that may work.
I am pretty sure that the adjustable end goes in the shifter box and the fixed end connects to the trans levers , but it still sounds like you have a mix match of original and aftermarket parts .
As far as bushing , use bronze instead of delrin or buy what Brewer makes .
