Originally Posted by dd340
Any suggestions?
I read your last post, I think the ground to the original box got corroded bad enough to limit the amount of voltage the box was getting to operate on twocents
I would put it back on after making sure there is no corrosion on the bottom mounting surfaces and see if it is okay or not scope thumbs
