The owners manual only lists The V6 for towing they probably would void warranty if you had drivetrain problems with the other engines.
I tried a BACK DOOR way through the FCA parts dept to get “approval” !!
If they have a hitch available through the parts dept and there’s a listed charge for an install - THEN that might be acceptable. But nothing is available.
Does that make sense that a 6 banger would be allowed.... and a 5.7 or 6.4 would NOT BE?
The transmissions in the V8 cars have to be HD.
I’m not looking at doing ANYTHING heavy ... maybe a small boat or jet ski
