I don't have an owner's manual for the 91 Ramcharger, I'm looking for the recommended fluid to use in the power steering.
My 92 Dakota says ATF, but it is rack and pinion.
I've used ATF in other 1st gen and older Mopars, but this is going to be a new steering box, pump, and lines, so I figured since I'm starting from scratch I may as well use what it called for.
It's primarily a winter and crappy weather beater, so the best flowing fluid for cold weather is best option.
