Hi! I am re-wiring a '77 W-200 truck and just ran into a small problem. A circuit breaker with a small 3'-ish wire harness attached to it is located at the fuse panel. I can't find out what the other ends in this harness should be attached to. Can't find the breaker or the harness in the wiring diagram either. Pictures show the breaker, its terminals and harness. Any ideas? Thanks
