Originally Posted by Pacnorthcuda
Originally Posted by Sniper
Originally Posted by 73cuda340
Wouldn't the 16:1 manual box require the same amount of effort as the factory power box with the pump not being used? I don't mind it at all with the amount of effort required. Just curious as to how much of a difference, if any, there is between the two.
Manual cars come with larger diameter steering wheels for more leverage and different alignment specifications for a bit of help with low speed steering, so no the effort is not the same.
...and I honestly thought I’d heard it all....
Why don't you go look it up then
