The Lunati 60303LK 226/234 @ 0.050, 0.494"/0.513" lift, 110 LSA would be a good pick, and it is one of the least expensive cam/Lifter kits at $180.
If you are going for more power, the Comp XE275HL cam is really nice, 231/237 @ 0.050", 0.525"/0.525", 110 lsa, and the cam/lifter kit is only $210 from summit racing.
The Hughes HEH2832BL3 cam (228/232 @ 0.050", 0.524"/0.540" lift 110 lsa) should give you the torque of the milider Lunati cam and near the HP of the Comp cam, but it is the most expensive at about $270 for cam and lifters.
Anyhow thats my
