Lunati Voodoo .454/.475 is good with lower compression. And will work ok with your stock valve springs. If you want more HP go with the .475/.494. You'll need new springs for it though! Both are great street cams And work with MOST of your stock components.IE> carb/intake/valvesprings/converter-etc
