Originally Posted by moparx
a timely topic for me, as i was wondering what place[s] are the "go to" for the purchase of said rings ?
any recommended sources ? [as always, TIA ! boogie]
beer
I cut these down on my lathe to fit
LINK
i was thinking about doing just that.
easy to do.
how tight of a tolerance did you use ? i was thinking "tap in fit" [OD] for the wheels, and .003-.005 larger ID for the axle flange hub.
beer
This, yes
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
