Surprise! Some steel wheels are worth more than aluminum ones. Because they bend so easily, they need replaced more often.
I have bought a set of aluminum wheels for not much more than a pair of steel ones. That is, of course, if the rims are the same diameter. Going to the aluminum wheels upgrades the look of the car and puts an end to most of the more common problems with bent steel wheels. Not all, but most.
Master, again and still
