The switch comes out pretty easy.Remove the plastic face plate after you remove the round warm piece.Small allen screw holds it on.Then the panel that houses the push buttons comes out.The cable for the heat control is also attached but usually has enough to get to the vacuum switch.It unscrews for the metal panel.The vacuum lines attach to it.Probally broken as most are.Rocky
Chrysler Firepower
