It would be best to know what the current combo is, or the expectations
I think the Indy programs are pretty good....... but if you’re trying to build something that requires something “more” that what they can deliver....... then going a different route may be a better option.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
