Sorry to hear of your troubles with the hyd roller!I did'nt go hyd for this reason and went with a comp 829 solid body.Do you use a factory block?Could you tell me the push rod length you use? Factory block and pushrods were 8.9ish on the length? I have the measurement somewhere from when I ordered them....
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
