Originally Posted by roy282
Thanks for reply, but not what I was hoping to hear, thought maybe it was a high volume aftermarket oil pump
Thanks,
Rob
If you're running a stock oil pan and your oil clearances aren't on the loose side, then a stock type pump is what you want.
CHIP
'06 GMC 2500HD LBZ Duramax
