Try the 1850 carbs since you have them. They'll probably run horrible but at least it is a starting point. If you decide to go with Edelbrock carbs pick up a pair of the 500 cfm. Be sure to buy the ones that are calibrated for dual carb use. They should be plug and play on an engine like that.
