Originally Posted by BSB67
Originally Posted by Cab_Burge
I make all my own crank scraper from sheet metal, steel or aluminum. I'll use a piece of stiff carb board, like most after market gaskets come in and a oil pan gasket to get all the oil pan holes located properly and then measure and cut away wrench Once I get it where I like it I'll transfer it onto the sheet metal and finish the trimming it one crank journal at a time with it bolted downon all the oil pan holes wrench I shoot for between .030 and .060 radial clearances, depending on if the motor has steel or aluminum rods scope
I do like the way they bent the one side up on all the rods and put a drain back hole in it up bow
Kinda the same here. I make the template with almost zero clearance and have Kevin make it. Then I roll pin it to the block and hand finish grind it to about 0.040" clearance.
Kevin offered to redo the one if I mark all the mods to fit this magnum block and ship it back to him. I already started grinding to fit. Kevin recommends drilling and pressing in 2 small location dowels on each plate.
Like I said, it fit my 1965 273 block and stock crank much better but the gaps to the counter weights and rods were way too far on that 3.31 crank.
I am shooting for between 0.040 and 0.050 gaps.
What is your thoughts on my Date code on this Mexican block?
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
Posting cheap tech help (CRAP) here since Nov 97, 1000's of posts, some may be good.
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
