On the outside of the firewall at the “start” terminal in the bulkhead, I have a wire going to the “start” terminal on my starting solenoid.
In the “run” terminal on firewall side of the bulkhead , I have a wire going into the ballast resistor, Then out of the ballast resistor to + pole on the coil.
This is what’s happening ;
I have power to coil in “run” mode but when I roll the key forward to “start” it cuts power to the coil. It will turn over fine but it won’t fire. At this point I have no spark
(1) The ST terminal on the ign switch goes out to the yellow wire (ign) terminal on the starter relay for cranking. (2) Seperately the brown wire (ign2) circuit goes from the ign switch out directly to the coil positive primary terminal for full voltage starting. (3) You have the blue wire (ign1) "run" circuit correct from the ign switch out to the upstream side of the ballast resistor for reduced voltage when running.
