I like correcting pushrod angularity, but this must be weighed against "does it require a smaller pushrod OD than the other lifter choice"? The usual rule: if you're not sure your pushrod is the largest one that fits... it's too small.
I don't like the resulting angles with the offset rockers and lifter seats, but I suppose it's still less extreme than a Gen 2 Hemi valve train.
