Originally Posted by Andrewh
are you concerned with it looking right or are you concerned with the quality if you got it somewhere else?
have you considered the adapter and the more modern master? if you aren't restoring or making it look stock that is.
I want good quality and for now anyway, I would like it to look right. I also don't want to have to redo brake lines right now. I might put disc brakes on it eventually, but for now, I want to drive it.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
