At what rpm are you shifting? Didn't look like it was going much past 6000.
I was shifting around 6500. The Rev limiter you can't here it. But I had to go change it to spin it higher. Plus it was a little lean I think yet as it was not climbing rpm real quick yet. Ran out of jet sizes at #106....
And it needs a full cage and window net anything below 6.50.....
After reviewing a copy of the vids it appears I shifted closer to 6200....
