1966 poly 318 2bbl car engine, how does the chain get oiled? This car will be stock and driven a lot in summer.
The top right bolt hole for cam plate is a blind hole and all bolts are solid, no oil hole bolt like what mopar performance sells for LA engines.
No oil trough in there like the photo from 1978 service manual . Also the 1978 manual shows the cam plate has a oil slot in it. Should any upgrade be done or put it together in stock form?
Don’t know why the photo is upside down, sorry.
