If you pull the oil pump make sure and remember to put the long bolt in the pump before you install it. It's the last one I take out after removing the other three. It's too long to remove and stays in the pump as you remove it. It drops down and will hit the k member but is out far enough to allow pump to be removed or installed easily.
