Stay away from one with the 4.7 motor.
By the time you get a 4 door/crew cab on a Dakota, there isn't much difference between it and a full sized truck. That is the primary reason the Dakota trucks went away. If you want or need a 4 door or crew cab, get the full sized truck. Gene
