Originally Posted by TJP
Originally Posted by Cab_Burge
The inner large axle seal is in the housing, the outer is on the axle scope
I install them in all the rear ends I work on, even with the green bearings to help stop gear lube form leaking onto the brakes and the backing plates up
iagree but don't use green bearings grin beer
I've had to use the Green bearings(from Dr Diff) to put a 35 spline axle in a 8 3/4 housing along with the Dana 60 inner axle seal with good results up
