I agree, the Hot Wire engine harness solves a lot of issues, mainly because the harness is stand alone, plug and play. You don't have to sort through the factory harness and try to eliminate what you don't need.
But, it seems too many Mopar guys are afraid to come into the 21st century and want to keep the ancient stuff. Mopar was one of the first auto companies to come out with electronics and for the most part the highest majority of those electronics after the early few years of use have been very reliable.
It appears by reading Moparts the modern electronics are more reliable then the Mopar brake system or the carb/fuel or old time ignition related systems are.There certainly more posts asking questions regarding those items then there are covering modern electronics. Gene
