Tried the paper clip on diaphragm shaft to see if secondaries are opening up. Paper clip didn’t move down the shaft more than 1/8 of an inch, maybe a little cocked from where I put it but probably vibrated there. So would that be a bad diaphragm or bad vacuum pressure? Should the diaphragm shaft be able to move up and down by hand when car isn’t running? (Remember I spelled Holley above without the “e” 😬)
Also running in 2nd gear had no effect on the bogging down. Still bogged at a slightly lower speed
Any more suggestions?
Have you checked your dwell recently ?? Just had a 66 vette that would shut off at about 4K, dwell was set at 19. Reset to 30 and all is well to 5500,
