One pushbutton valve body won't manually shift from second to third "under load". Otherwise shifts automatically and from first to second under load fine.
So I swapped out valve bodies and now this body shifts manually and automatically fine, but drags the engine down from about 4500 rpm up. Engine comes up and starts to "stall/drag" at higher rpms.
Any ideas?
