Just wondering what you guys would suggest is the best cam for my 440. Engine has 9.6-9.7 compression (I couldn't get a real good number of CC on the valve reliefs--so this is my best estimate), both engine block and heads were cut 0.020", it has cast iron "346" heads, stock magnum exhaust manifolds, stock intake manifold, 4 speed transmission and 3.91 rear gears. I do not plan on racing the car just want it to have good pick up, do a nice burnout and run good so I can drive it to shows. The car is driver quality and not a show car. Thanks in advance.
