Originally Posted by madscientist
That's usually a blown power valve, or most likely, if the rear block has a provision for a power valve and you are running a plug (or even the power valve) that plug (or power valve) can be hitting the boss in the power valve well in the main body.
Look very close at the boss in there. Take the gasket off the metering block and with the PV or plug installed make damn sure nothing is hitting anything.
iagree scope
