It has 4 coats of clear on it. First coat was pretty light and dry. Second and 3rd coat were medium coverage, and didn't look bad. $th was because I had enough mixed up, to cover it, and didn't want to just waste it, since I knew I'd be wet sanding and buffing anyways. I'll knock it all back down with 1000 grit, before having the lettering, and pin striping done.
69 GTX 68 Road Runner
