Originally Posted by 03heavy
From what I’ve been able to find it should work
I have to mount my 6.4 vvt to engine run stand and see if it will run
At this point I have swapped the reluctor wheel for the 32th tooth
Also the crank and cam sensor for the older style
And locked the vvt
I used the msd harness for the 09 and up cool packs
I should know if it will run in a few weeks
Exactly what I plan on doing.
Post some pics of your break in stand please.
