If you really want to make them tight tight, put them in a vice and squeeze them just a little. Make them oval. If you look at the factory female plugs, they are a little ovaled. I could not believe that a new harness from H&S did not have these on. I had to find them locally and replace the "female connectors" they had on. Pretty lame for a $500 part.
