Originally Posted by John_T_Brown
The ARC switch panel will not work unless you figure out the pinouts on the ribbon cable for switch power and each load switch (on/off). I believe it could be done but it will take a lot of work with test equipment.
Its the old one...no pin outs to worry about.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
