Quote: It would be using iron heads for the time being, aluminum when the budget allows.
You know that you'll need to be a little creative to do this and have both good quench and reasonable CR under these two conditions with out changing pistons - right?
I would not go over 10.5 CR with aluminum heads, based on what you describe for your combination.
