Originally Posted by PurpleBeeper
Have you ever tried taking those lines off? At least one seems to get stuck every time. I think I might try bearing grease myself next time
If you want to make it real easy,flare a piece of 5/16 copper tubing,cut off the flare and insert in fitting,you'll only need one wrench to remove and you'll never have any leaks !!!
