Yeah, the ones with the rubber/Viton in the ID area are the best, I use 'em on the pan drain plugs. I hate leaks.
In a pinch, nylon or soft copper is good.
Never understood the use of hard washers for that purpose, except maybe to keep the wrench from scratching the pan...
